DMZ link configuration has changed, or bandwidth reported by I3 of an interface configured as a DMZ link has changed. The routes in the given Adj-RIB-In are modified adding, removing or altering (as appropriate) a DMZ link extended community attribute containing the link bandwidth.
No remedy is available.
Info
An Adj-RIB-In is being recalculated as a result of a change to DMZ \nlink configuration or to bandwidth reported by I3.\nRIB Manager entity index: %p1%\nNeighbor Index: %p2%\nAFI: %p3%\nSAFI: %p4%
| Name | Type |
| p1 | uInt32 |
| p2 | xInt32 |
| p3 | uInt16 |
| p4 | uInt8 |
